Of course, this also means a couple of other things:
The ar is over 100,000 now
Half of the miles are mine
I've put 50k on in 22 months!!
post-6798-0-90593600-1421188401_thumb.jp
"I've put 50k on in 22 months!!"
 ^This^ seems to be what these cars like best...along with regular maintenance of course ! Keep driving :thumbup:
I daily-drive as well but 50K miles in 22 months, ... now, that is out of my comprehension!
I assume it is mostly highway driving miles.
Nonetheless, good on you!
Keep on hauling!  I have put the same amount on mine in about the same time...in the same make and model!  I'm at 120k+ right now.  Had 69k when I bought it a year and a half ago.  Get ready for water pump replacement soon if it has the original still on there.  Hopefully the clutch will be much later, depending on how the car was driven before you.  Glad to see someone else enjoying the car the way it should be! :clapping:
LOL! I did the water pump just before X-mas...it was the original and the bearing went. Did the low temp t-stat while I was at it. Last year, around 70k I did the clutch and IMS (original dual row IMS seemed perfect when it came out). I'm looking forward to the next 100K!
