That cover is on a hinge pin so there is no real adjustment. Perhaps someone bent it trying to remove it (improperly).
You might be able to carefully bend it back.
If not then I am pretty sure you would need to remove the glove box to remove the cover hinge pin and take it off to bend/fix.
