Just acquired the 03 TT.  Apparently there is no Nav CD.  Where the hell is the slot for it.  There is nothing apparent in the trunk or under the passenger seat.  Also if I do find it where is the most cost effective way to get a nav CD?  Is there any way to copy the CD from my 04 Cayenne Turbo?
Thank you in advance
Hmmmm.  Both MY'04 Cayenne and MY'03 996T use PCM2.0 (albeit slightly different in size), and the CD drive is in the same place on both - in the position deepwater describes.
The navigation CDs are the same for both, so you could copy your Cayenne CD.  Just use a computer to copy the CD onto a good quality blank CD-R and burn it at the slowest speed you can.
