Check the pictures I took. As Ahsai said either AOS first and then manifold (his descriptions) or the other way around (my pictures). In your current state I would lower the engine, remove coolant tank, buy and modify ratchet wrench as described and tighten the bolt. Maybe it will work without removing the tank or lowering the engine but it was not enough room for me.
In case you want to see what's going on use a Gopro or a phone and stream the video (Ustream app).
I have to stop right now, but i was able to get the other 10mm bolt loose enough to move the aos.
B/c the wire harness is in the way, i jammed a longer extension in there and proceeded to reinstall. I have use a 1/4" 10mm socket since that is thinner and that did the trick.
But, the extension that was on the aos bolt came off, but still in the general area. I think i can work with this later.
If you lower the engine as much as it goes, you could get that aos bolt from the bottom with a mini ratchet and 5mm hex bit like I described in the first post of this thread. You attack from the top of the cam cover around cyl #3, directly from the side.
Success! i had issues with moving the wire harnesses out of the way, but i had tightened the aos first and then moved the manifold into place and threaded the forward most bolt. Before installing everything, i had threaded it in w/o having the manifold installed. This way i could thread it in with my fingers most of the way once installed.
I had to use a small 10mm wrench to tighten it from under the manifold. It took a few minutes but it worked. Now i need to put the intake tubes back in and get some 4mm vacuum tubing.
Intake tubes are a PITA. I put them on with the manifold as it was too difficult for me to squeeze them in afterwards. I was able to rip them out but the other way back didn't work for me. Putting in the manifold with the intake tubes gives some stress on the green manifold sealing rings. You have to be very carefull that they don't get stuck on other stuff which is in the way.
What i did was to remove the passenger side manifold and wiggle everything together. I have to get some of the 4mm vacuum line for what i had damaged. When i removed the connection from the alternator, the plastic connection broke off, So i'll need a new voltage regulator. I can live with those repairs.
I am hoping that everything starts when i get it all put back together.
All is back together after replacing the voltage regulator and the 4mm vacuum line.
It started up after the fuel ran itself through the lines. It runs rough sitting in the garage from 1-2 rpm but seems to rev decently higher.
I wonder if it's a bad vacuum line, something not connected correctly, fuel injector not installed/connected properly, or even coolant in with the plug.
I would hope it's not the last one, but i do have new plugs. The old ones worked fine before. So far no cel codes.
At this point it could be a few things.
I am done. I don't know what i wiggled around or whatever worked itself out, but the grey dragon runs well.
I have replaced the fuel rail, fuel injectors, starter, some vacuum line, and the aos. I will save the new plugs, brake lines, brake fluid reserviour and flush the brakes this winter.
