Just wondering will a MK2 C4S transmission fit into a MK1 C4.   Engine sizes are different 3.4 vs 3.6, but would the transmission compatible?
thx,
Do a search. :). I assume manual transmission? I just asked this same question a week or so ago. Apparently the answer is yes. The G96/30 and G96/31 are interchangeable. It appears the only real difference is that the G96/31 has an extra input shaft bearing. Gear ratios as well as bell housings are identical. I too am having my 99' C4's transmission replaced with a MK2 C4S transmission as I type this, what are the odds... What went wrong with your current gearbox?
  • 5 weeks later...
Thanks for the input.   I have an oil leak as well as gear pop-out issue.
I read an article about the swap from G96/30 to G96/31 and found that the front output shaft is 2" longer.
Do you experience the same issue?
-sm
