996 Rear Diff Seal Replacement (drivers side)
I had a differiential leak from where the axle assembly meets the diff on my 1999 996 Tiptronic.  Determined it was the diff seal.  Following are the steps taken to replace.  I would say that changing this was a 'moderate' job.  The seal was about 40 dollars. Time about 2hrs.  Key tools were   1) ball head hex wrenches to remove the axle from the diff, 2) 32mm socket to remove the axle bolt (may not be necessary) 3) Air hammer to free the axle shaft after it was separated from the diff (may
