I was trying to remove the airbox and can't get the mass air flow sensor plug off. Here's a picture of the plug
post-62675-0-92811500-1417971463_thumb.j
Edited by mikeh10
There's a tab on the other side of the connector that you have to depress really hard with your finger/thumb and then you can wiggle the connector out.
Edited by Ahsai
A two-handed operation on this one.
Pull back on the tabs (orange arrows) while squeezing in on the tabs (green arrow) buttons. Once on each side.
It will likely be easier when than cold - plastic gets stiff and brittle when cold.
