hi,
i have some loud cracking noise's in my passenger door.
on most small roadbumps it makes a cracking noise - not funny!
any idea what i can do?
thanks
Have a look at TSB 3/00 7059 Noises In The Door/Door Trim Panel Area (dated 6-30-00). It is likely one of the items below (all are covered in this 7 page TSB).
Complaint 1: Rattling and knocking noises from the entire door area (left or right side).
Complaint 2: Creaking noises from the front or rear of the door area (left or right side).
Complaint 3: Clicking/crackling from the area of the side airbag.
Complaint 4: Creaking in the area of the inner door release.
Complaint 5: Grating from the door lock.
Complaint 6: Clicking from the area of the inner door (power window).
hi,
than you for the fast answer!
now i have found 7059 in the TSB section. but i can only read the date/number/title, i can't find there any information or something else?!?
where can i find the information for solving my problem?
thanks
:oops: only Contributing Members can view TSBs online.
I sent you a PM.
I have the same problems, along with creaking noises near the sunroof. It would be great if you can help with viewing the TSB. Thanks.
Ed
I sent you a PM.
Ed
Great way to view the TSBs is to click the "PayPal - Donate" button thats at the bottom of every page. Loren will then upgrade your status to 'Contributing Member' and you will be able to View all 711(!) TSBs, including the 215 that are applicable to your car... :rolleyes:
