Hi All,
I posted a couple weeks ago about swapping out seats in my 04 Cayenne S. Thanks for the advice on that. I had planned to swap out seats I had found, but that is prooving to be a challenge for the following reasons.
1. First set the junkyard sent did not have memory
2. Second set they sent had memory, but not heated (at least I think they are not heated since they do not have a relay).
The only reason why I was swapping out the seats was to get my heated seat working again (everything else works)
My questions are:
1. In 2004 were there heated seats that did not have the relay under the seat?
2. If there are heated seats from 2004 without the relay under the seat, I assume those would not work in my car that has the relay under the seat (correct)
3. The seats that came with my car are they PD4 Electric CMFT Pkg Spt/CM Seats / PEC Comfort Seats with Memory. Is it possible to replace just the element in this seat, or are they sewn into the leather. If it is possible to change just the elements, any clue on the part numbers?
Any other advice on how I can get this heated seat working again, would be great. I have tested the switches and the relays, and occasionally, if I sit the "right" way, it will work.
It sounds like you have all the components you need.  Just swap the components you need to build the seat you want.  The electronic bits are probably easier to swap than are the heating elements.
