I have a exhaust muffler for my turbo which i want to install. I would like to try to do this job by myself. There is just one question open and i would like to ask your advice.
The exhaust Pipes are 70 mm in diameter.
What is the diameter of the original Pipes?
The rear end pipe tips are 70 mm too. What would be the best way to connect them?
Thank you !!!
Thank you. Its not about the clamps. The Problem is the the pipe tips are 70 mm and the connection pipe from the muffler is 70 mm too. You can not telescope the parts.
Hahnmgh is right. Sleeve clamps are designed to joint two pipes with identical diameter, exactly your case.
Just google images of "Porsche sleeve clamps". You need the correct size though. Usually Audi and VW ones are cheaper.
Hahnmgh and Ahsai.....
Thank you. Now i know which Design to look for. Sorry. Because of my poor english i didnt get it in the beginning
