Clarksongli, I am pretty impressed that you were able to figure out how to remove the turbo without dropping the engine. Kudos to that.  What was going on with your turbo that prompted you to undertake the removal?
Now if SpawnyWhippet can get a DIY together.
Thanks very much for that helpful advice clarksongli. OK, so I am going to give this a go. My left turbo is cracked, so I ordered the cheapest used one off fleabay for $350 shipped and had it re-manufactured by Turbo Park for $390.
My parts guy at the local stealership said I also need the following:
Left reman turbo                             948-123-016-56                 $790
1x o-ring                                          999-707-544-40.                $2.64
3x seal rings                                    900-123-131-30                 $2.64 each
1x rubber o-ring                               999-707-387-40                 $1.07
1x rubber o-ring                               999-707-392-40                 $2.64
5x seal rings                                    900-123-005-30                 $1.07 each
1x exhaust gasket                            955-111-113-20                 $12.02
1x exhaust gasket                            955-111-113-10                 $14.29
8x hexagon nut                                N-908-946-02                     $0.81 each
1x exhaust gasket                            948-123-203-52                 $13.28
1x green o-ring on pressure pipe    955-110-720-00                 $4.61
Altogether I am down $800 in parts, which beats the $7k my stealer is quoting (so long as it all goes together OK).
Edited by SpawnyWhippet
So I have all of the turbo disconnected and all bolts out except 1 pipe which is preventing the turbo coming out - the one beneath the turbo. Any ideas how to undo this while the engine is still in the car?
So I am thinking of cutting this bottom pipe and making a union. This would make it far easier to remove the old turbo and install the new one. Question is, what kind of union is available to make a good, re-connectable joint here?
Some progress. I cut the lower oil pipe to the turbo which allowed me to lift it far enough to unbolt the remaining bit of pipe from the turbo with a box wrench.
The turbo is now entirely free, but it will not fit through the gap at the front, it is just too big. I am now going to try to remove it from below by taking out the primary catalytic converter exhaust pipe.
Turbo is wedged in at this point, between the exhaust manifold, engine block and side bulkhead.
Looks like I will have to admit defeat,even when dismantled the turbo housing is too big to come out the front or the rear gap of the engine bay. I have no idea how clarksongli did this without removing the engine or exhaust manifold, which itself looks like an engine out job.
With some mechanical butchery to the old turbo, releasing the engine mounts and jacking the engine up as far as it can go, I hacked enough off the old turbo to wedge it out the front gap. This is very much not recommended, and the turbo is certainly at least an inch bigger than the gap it has to come out of. Now working on a way to insert the new turbo, but it looks tough or impossible. I could make it easier by removing the exhaust manifold now, but I don't think there would be a way to reinstall it when the turbo is in place, as the rear bolts would not be accessible.
Can anyone recommend a good independent near the Bay Area peninsula who could finish this at a reasonable price?
  • 3 years later...
I managed to complete the job, but it was not easy.
RENNLIST.COM
DIY Submission Forum - DIY to replace Cayenne turbo without dropping engine - I am writing this DIY as I couldn’t find anywhere that described how to DIY a left turbo replacement on a 2005 Porsche Cayenne Turbo, and all the mechanics I spoke to said the drivetrain must be dropped out the car to do...
