Last time I changed my oil, I used fiber drain plug gaskets from Napa because I couldn't find aluminum crush washers big enough.  Next time I will just order a kit online.
Just recently, I noticed oil dripping from my car through the plastic cover.  I took the cover off and noticed that both drain plugs were loose so I tightened them.  My question is this:  Is there an issue with fiber drain plugs on the cayenne?  Or did I simply not tighten them sufficiently.  I didn't use a torque wrench.
Working on an 04 Cayenne S.  The gaskets are in fact fiber and not plastic/nylon.
Thanks for the part number.  Any chance I could salvage this oil change?  I tightened them up.  Warmed the car up to operating temperature.  They were then loose again.  tightened them up again and now they seem firm.  It looks like the fiber washers squeezed out but there's no significant leaks after running the car.  I just don't want to have to remove the plugs and lose a bunch of expensive oil.  Although granted, an engine is much more expensive.
Edited by daviegravy
It sounds like the drain plugs will loosen unpredictably as the oil pan goes through temperature changes. I think you risk over tightening on one hand and catastrophic leaks on the other. Get a clean container, drain and refill.
It looks like you all know all about the cayenne
2006 cayenne windows fogging
Passenger side front and rear carpets are soaked..
I he ve opened the drain in the footwell cover and blow air to it i have been drying the car with a space heater last three nights.
Did I resolved the issue or do I have to be worried?
