Look like an older set of coilover springs/struts (not factory option on standard 996 series - only GT3 came with coilovers).
You might want to measure the height at the center of the wheel arches (side to side) - if they are off by 1/4 inch or more you likely need a 4 wheel alignment and height adjustment.
How can i test if these coilovers are still good? Car feels fine and does not bounce. Do these require some special maintenance?
Same way you test any springs and shocks.
Look for leaking or damaged shocks likewise look for damaged coil springs or very uneven height side to side (that can not be adjusted out).
Coilovers are great for the track but a low ride for street and can be a bit bone jarring.
