Just want to make sure....were these values measured on a fully warmed up engine with the car stationary? Also I think Torque displays the MAF reading in g/s. Did you already convert your reading to kg/hr numbers I showed in my previous post?
  • 4 weeks later...
Ok guys Finally figured it out....after checking trim values a million times and ensuring there were no air leaks, I began thinking that maybe the "new" MAF was defective. So I bit the bullet and purchased another MAF.  I haven't had a CEL since.
I want to give Ahsai a shout out along with all other contributors for all the info and recommendations. I learned a ton about my car while tracking this ghost down.
Good job! Glad you got it sorted now. Just to be clear, you bought a new Bosch MAF sensor and that was bad and you replaced it with another new Bosch unit?
Edited by Ahsai
