All,
I have a 1999 996 Cab and a while back the horn pad(airbag) became very sensitive and would sound at teh slightest touch.  Then it got to the point where the horn would sound non-stop until i pulled the fuse.  I tried changed the mounting bracket between teh airbag and steering sheel in case the rubber mounts had worn but this did not work.
I had a friend tell me that sometimes on cars the airbags and horn switch within the airbag becomes faulty and you need to replace the whole airbag piece.  Anyone run into this?
While you waiting to fix the bushings, tear of the cover from a match book and roll up and place in crack of steering wheel between airbag and wheel.  It will keep it from honking.  (Not a permanent fix however)
Edited by kbrandsma
Or just pull fuse B3 until it is fixed.
I've had the fuse pulled, for about 6 months :-)  I replaced the bushings plate 4 months ago but maybe I tightened it too much because it kept sounding.  will try to loosen the screws.  thanks guys!
thanks guys!  I had tightened the 2 screws behind the steering wheel too much when i replaced the new rubber bushing plate.  Should've asked 6 months ago...
after a few twists to loose each screw, working as designed
