I was hoping to use the "open glove box" method so that I can tell when my doors lock. (For those not familiar with this: there is a beep when you lock the car and forget to close the glove box.)
Unfortunately, this did not seem to work. I thought that I might have left the wire unplugged after my most recent removal of the rear center console to install the SSK. So yesterday I removed the console, but the wire is still attached to the plug under the glove box lock. Any ideas? :(
Is the switch broken? You can test it with an ohm meter.
Other common areas are the front trunk microswitch and not having the sunroof or top closed all the way.
