Does anyone know the part number for the TORX bolt used to attach the seat runners to the car body? There are 4 of the same size that hold my seats down.
I managed to almost strip the head of one putting one of my seats back after fitting my fire extinguisher bracket and would like to replace it, but the local Porsche dealers are somewhat clueless...
Car is a 2000 996 coupe with power seats.
Thanks.
999 141 038 07 Torx Bolt (E12)
All seats EXCEPT the (RoW) GT3 seat use the same bolts.
Loren,
If I am reading PET correctly, wasn't that part number superceded by 999.141.039.07 in 2003? It appears to me this bolt is now used for all seats, including the GT3 buckets (XSE/XSF).
Karl
Loren,
Karl
Karl,
The seat bolts did change from MY03 on (999 141 039 07). If you could/should use those new bolts on older cars it would have a "Dropped, please use replacement" pop-up window with the new part in it. Try item 11 (996 521 364 00) on the same page and you will see what I mean.
Use an E12 female torx socket if that is not what you used. I can get them off with a 3/8" socket but it is a sloppy fit. Torque spec is 48 foot pounds. Jeff
