2001 Boxster S, 39,000 miles.  I've been battling with a P0133 code for a few weeks, it indicates a slow O2 Sensor Bank1 sensor 1.  I've replaced both pre cat O2 Sensors and the code came back after resetting.  I've pulled fuel trim data and it is unremarkable, both Long term and short term.  The data does show a slow O2 Sensor bank 1 sensor 1, but both are new.  So I swapped sides of the new O2 sensors hoping that the issue would switch to bank2....It did not!  :angry:  So, I'm out of ideas.  Thoughts?
The vacuum hoses are famous for causing air intake leaks throwing this type of code. If you remove the alternator the whole system is much more easily accessible via the service panel behind the seats.
post-16716-0-68154300-1403796648_thumb.j
