2011 Boxster S
How do you turn off the lights in the hood or trunk if you have them open for an extended period of time?
You can do a number of things.
  1. You can leave the hood open and manually latch the catch to trick the system in thinking the hood is closed.  Place a rag or something in the latch opening to remind yourself to disengage the latch before trying to close the hood.
  2. Pull the fuse
  3. Disconnect the light
  4. They will automatically turn themselves off after about 30 minutes or so.
I usually do number 3.
Edited by kbrandsma
