Pulled DTC P1699, voltage at battery with engine running at idle is 13.6. Cleared code and P1699 returned shortly.  Can some one provide me with schematics for the charging system?  I'd like to test continuity from the alternator to the ECU.  Any other advice is welcome. Thank you.
