Does anyone understand the function of the two different buttons which control the Sport setting(s) of the 997 S? When both are in Sport mode, the car is very hard riding, but feels peppier. The throttle seems more responsive.
From the 997S Technik Book:
Porsche Active Suspension Management (PASM)
For the first time in the 911 series, the new 911 Carrera S is offered with a chassis that has actively adjustable dampers. The PASM is standard equipment for the 911 Carrera S. In comparison with the standard chassis, the vehicle with the PASM chassis lies 10 mm lower.
The newly developed, variable damping system “Porsche Active Suspension Management” helps to do justice to the demands for a modern chassis. The aim was to maintain the high comfort level of the standard chassis while increasing performance at the same time.
The driver can choose between two programmes: “Normal” and “Sport”, both are selected via a button on the centre console.
The function light in the button comes on with the Sport setting. At the same time a damper icon appears in the instrument cluster display together with the text “PASM Sport”. When the normal programme is activated, the damper icon appears accompanied by the text “PASM Normal”. The text and icon remain visible for 4 seconds and then disappear.
PASM combines two chassis rolled into one: One with equal measures of sportiness and comfort and one entirely dedicated to sportiness and the race circuit. Normal mode (the basic setting when the vehicle starts) on the one hand provides the same excellent comfort as the standard chassis, on the other hand, the chassis approximates the sportiness of the sports chassis when regulative interventions are made with active PASM. In conjunction with specially developed software modules, the PASM ensures excellent performance and even greater driving safety in extreme situations.
Operating principles of PASM
PASM selects the required damper hardness for each individual wheel from a precisely co-ordinated map in both the Normal and the Sport programme. The possible damper settings range from comfortable to decidedly sporty. Both programmes, which overlap slightly in some areas, are additionally superimposed with five special software modules to provide the optimum damper settings for every driving condition.
The system automatically selects the appropriate damper hardness based on the PASM programme selected and the driving condition identified.
The Normal programme offers comfortable settings with low damper forces. Special control algorithms in the PASM software modules enable the chassis to offer greater active driving safety in extreme driving situations, even with the Normal programme. To increase driving safety at higher speeds, the dampers are automatically switched to a harder damper setting as speed increases.
The dampers switch to a hard characteristic when Sport mode is activated. This offers superior agility and excellent steering precision on uneven surfaces. If the system detects an uneven driving surface in Sport mode, it immediately switches to a softer characteristic to improve contact with the road surface. PASM selects the optimum damper setting for this softer characteristic from the Sport map.
Since extremely hard damping is not always the ideal solution in every driving situation (depending on the driving surface, the vehicle may start to bounce or shift), the intentional overlap between the Normal and Sport maps allows a noticeably soft setting to be selected if necessary. The customer gets an “active sports chassis” which automatically responds to the actual road surface and switches from a hard, sporty damping setting to a comfortable range as necessary. PASM switches back to the original characteristic as soon as the road surface is smooth enough.
The following is a detailed description of the five software modules overlapping Normal and Sport mode.
Lane-change module
The damper forces at both axles are immediately increased in response to rapid steering movements, for example sudden evasive manoeuvres. This reduces body tilt and instability, thereby significantly improving vehicle control even in extreme situations.
Vertical-control module
In the Normal programme, the damper force is increased as soon as the vertical movement of the body, for example when driving over uneven surfaces, rises over a specific threshold value. This prevents body instability and therefore woolly driving behaviour.
In the Sport programme, the damping is slightly reduced automatically to improve contact between the road and the wheels as body movements increase. This also results in a noticeable increase in comfort.
Lateral-acceleration module
If specific, speed-dependent thresholds for lateral acceleration are exceeded when cornering in the Normal programme, the damper force is increased by different, defined amounts for each side of the vehicle. This prevents vehicle instability and significantly increases driving precision.
In the event of large vertical movements and high lateral acceleration coinciding, the higher of the vertical-control and lateral-acceleration damping values is set. This happens if, for example, the damping in the Sport programme was previously decreased by the vertical-control module.
Brake module
PASM switches to harder damping at the start of a braking operation to reduce vehicle nose-dive when braking. This way, higher brake forces can be transmitted to the road faster. It switches back to a softer setting (this setting is different for the front and rear axle) after a specific amount of time. The result is improved road contact, and thus a shorter braking distance, particularly when braking on uneven surfaces.
Load-change module
The damper characteristics for the front and rear axle are individually switched when accelerating heavily, releasing the throttle or changing lanes. In Normal mode, the dampers are briefly switched to a harder damping setting in these driving conditions. This avoids excessive lifting or diving at the front of the vehicle (“pitching”). In Sport mode, a softer damper characteristic is briefly selected if necessary to improve traction when accelerating, particularly on uneven surfaces.
Components
The PASM system comprises the following components:
• Four dampers with continuously adjustable damping force (each with one bypass valve)
• PASM control module
• Two acceleration sensors for detecting vertical movement of the body (one at the damper dome at the front right and one at the rear left). Further signals such as lateral acceleration, steering angle, travel speed, brake pressure, engine torque, etc. are read in via the CAN bus.
• One button for selecting the programme (Normal or Sport)
The system measures body movements via one acceleration sensor on each axle (front and rear). Values such as lateral acceleration, steering wheel angle, vehicle speed and information on possible braking operations are provided by the PSM via the CAN bus. Engine rpm and torque values are provided by the Motronic via the CAN bus.
Basically the suspension button stiffens things up without messing with the basic PSM or throttle response.
The Sport button stiffens the suspension plus increases throttle response while letting you get away with a little more before PSM reels you back in. B)
I find the SPORT Suspension setting very hard on the street. The car handles dead flat, but I don't enjoy driving the rough roads of Pittsburgh. I can't wait to try the SPORT setting on the racetrack....I'll be attending a PCA Driver's Education event at Mid-Ohio!!
However, I really enjoy the Sport Chrono Package SPORT setting. This makes the car feel peppier while maintaining a firm but comfortable ride.
In order to activate these settings, I must first activate the SPORT button, THEN I must de-activate the PASM Sport button. Unless I'm missing something, this seems an awkward approach for probably the setting most of us would use most of the time.
Any thoughts?
