I assume that you checked the fuse? It seems like it's working like it supposed to if the fuse was pulled.
Check the fuse with an ohm meter, sometimes they are burnt and look normal.
good idea u4s.  I'll try both with ohm meter.  Would really like it working for a pending 2 day work out at the track!
Don't worry, it seems like it's going to get hot enough on the track to trigger the fan anyway! ;)
All kidding aside, I don't blame you, I would also want it working properly.
