Cayman R experiencing intermittent bucking or lurching in sport plus mode on the track on accelerator application. Occurs at high revs (over 6000, with revs bouncing up and down) as though it is expecting to shift up but doesn't. P1990 error code in PDK section (unable to apply torque). Dealers states software latest version, has no recomendations for fix. Suggestions?
2012 Cayman R with PDK. I purchased car this June as Porsche Certified PreOwned. Some 23,000 miles odometer. My understanding is that all Cayman R came with LSD. Could a worn LSD be the issue?
They need to re-program and calibrate the DME and updated the PDK software (again).
If that does not cure the problem they need to use your CPO warranty and replace the controller.
