on the front the wheel carrier (not the tie rod ball joint boot). i messed it up a while ago when i first replaced the stock springs for h&Rs. well, i kinda rigged it so the boot is partially sealing so that it is not completely exposed.
couldn't find any instructions on alldatadiy.com
tia
Is the part even available? If not you will have to replace the arm. Alternatively get some rubber sealant and cover the tear in the boot.
I've got a similar issue with the tie rod boot (oops!). I put some rubber cement on to try to seal the tear. Wondering if there is a better fix (other than replacing the whole control arm).
tia
I do not know if you guys used the porsche ball joint tool. If not then it is well worth the $120 investment. Aside from not tearing boots, it makes disassembly effortless.
You might try the junk yards for replacement arms, control rods, etc. You can usually get them for $100-$200.
ar38070,
I wish I had followed your (and others') advice about the ball joint tool. I didn't, and now I've got to deal with the consequences. Fortunately, I only messed up one side. I'm hoping the rubber cement will hold up for a while.
I don't see any reason to swap out the radius arm unless and until the boot fails and the ball joint gets trashed.
