Just started noticing the clutch engages about 5/8 out. This came about when I let two others drive our '99, with 52k miles. After they mentioned this, it seems to me that it does engage further out.
Is there an adjustment I could make to restore near normal engagement? :help:
Keoni986
The clutches on all Boxster and Carrera's is hydraulic and therefore not adjustable. There is a small amount of adjustment used to match pedal height in the clutch master cylinder connecting rod - at most 1/4 inch at the pedal.
I would bleed the system for air - and look for small leaks.
