Hey guys -
I'm running into a strange problem where when I turn my car off and take my key out, my electrical system stays on until I hear a mechanical click. I'm assuming this is from the lock assembly. Sometimes that click takes a few seconds, sometimes it's prolonged to a few minutes. I've replaced the ignition switch before and it seems to have worked for a few weeks, but then the problem returns. Does this mean it's the lock assembly?
I have no problems starting my car or pulling the key out, only when I try to turn off the car.
Also, not sure if this piece of information is important, but when I take the key out, I can't put the key back in until I hear the click.
Thanks for your help!
Usually replacing the electrical switch will do the trick. However I have found on several cars that replacement of the entire barrel assembly was necessary.
Hey guys -
Hi GForce83,
Your issue is the lock assembly intermittently sticking internally. The system stays powered up until you pull the key out of the ignition. You can try to take it apart and spray some lucubration in the mechanical part that locks the wheel. However if it were mine I would just replace the lock assembly as the R&R time is not worth going back for seconds. Hope this helps.
post-29211-0-37380900-1411283120_thumb.j
post-29211-0-43797400-1411283137_thumb.j
It is the lock assembly. Porche redesigned several times. It is a dealer stock item. I had the same problem. That fixed it.
Hi GForce83,
If you have not replaced your lock assembly yet I have a nice used one for $100.00 + shipping.
post-29211-0-02173500-1412294625_thumb.j
post-29211-0-42092500-1412294637_thumb.j
post-29211-0-66096400-1412294644_thumb.j
