The L/R brake lights arent working at all, voltmeter is reading zero when brake is pressed. 3rd brake light works fine. replaced bulbs and pedal switch. anyone have any advice on what I should look for to fix it?
On a 987 is the left brake light directly connected to the switch, the right and 3rd brake lights are connected to the rear control box via the switch. Check whether the correct switch is installed and if the fuses are still intact.
took it to the dealer, the piwis was unable to communicate with the rear control unit. is this something I can just order and swap myself?
