My 99 cab runs on Motul 15w50 and it suddenly shows arround 1 bar of oil pressure at hot idle, comming from 1.8.
I am not loosing oil and the other readings seems normal. 3.5 bar at 2000 rpm and 4.5 at 3000 rpm.
Could this be caused by a bad oil pressure sensor or is it something else?
regards
John
Very well could be. If you can't verify the actual pressure with a physical gauge, maybe just replace the sender as it's not expensive and it's easy to replace.
By the way, would there be any difference in the oil pressure at hot idle depending on if I use Mobil 0w40 compared to Motul 15w50?
John
