I was interested to get thoughts from the forum on if there is any benefit to replacing the aging vacumn and boost lines with silicone hose.
Depends upon the quality of the silicone hoses.  A lot of silicone hose softens dramatically as it warms, which is going to be the case in an engine compartment.  If you can get hose that is designed for the heat, you should be fine.
