I've got a 2003 C4S with Porsche P/N brake pads...  I can have brand new clean wheels and a 100 miles later the interior drum is coated in a nasty black dust from the brake pads.  I know if you get a harder pad then you can get squeally brake noises, and a harder pedal.
Does anyone have any solutions for this?  Is there any magic cleaners, I've used a lot of them, but they all seem to take some elbow grease.
What has completely solved this dilemma for me was to change to Hawk HPS Fero-carbon pads.  No pad dust, no squeal, good pedal feel, and long lasting.
One other trick to keep road dust, etc. from clinging to the wheel is to coat the inside and exterior of the wheel with Rejex, which is a polymer surface coating originally designed for aircraft.
Google both of these products to find your nearest distributor.
O.E.,
Wow, you're the concours champ, I looked up your winning ways...  My last concour fling was a class win at Pebble Beach nearly 30 years ago.  Thanks for the information, I have Rejex on the shelf.  I'll look into the the Hawk brake pads.  I hate the dirty wheels...
Thanks for the reply,
O.E.,
I've read where guys dump the vibration pads and are still waiting for the first squeal or chatter.  Would you leave them out, would you just replace the old ones, or replace with new?
For the original question you may want to try Armor All Rim Protectant.  It is a spray that you apply on dry rims and dramatically reduces the amount of dust that builds up.  I was sceptical but so far I've been impressed with the product.  It doesn't survive through a serious wash, but it only takes a few seconds each to apply.
I've tried wheel wax and a few others in the past but I never continued to use them because the effort to apply was too high.
I have also heard of people painting the inside of the rim with black plastic dip.  It doesn't reduce the dust at all, but makes it less visible.  I've been debating trying that myself.
+ 1 on the rejex, that will fix your dusk issues.
Since I have Rejex on hand I'll put the car on the lift and Rejex the wheels PDQ.  I think I'll also look into the Hawk HPS Fero
carbon brake pads.
Thanks to all that have replied...
O.E.,
I have also heard that some leave the vibration dampers off the new pads without any noise issues.  I chose to reuse the vibration pads on my 996.  I use a metal putty knife to separate them from the brake pads during removal.  The rear vibration pads are difficult to remove because there are two per pad, and damage easily when they are separated from the brake pads. New vibration dampers are pretty pricey.
