Just got the following errors and wanted to see if you fine folks can help narrow down where the issue is at specifically.
Codes were pulled with Durametric SW.
They are:
ME:
P1627
CAN timeout - airbag - Implausible signal, test conditions are not-completed, fault is currently active and is not causing a DTC light
Instrument Cluster
1321
Airbag triggering unit - No signal/communication, test conditions are not-completed, fault is currently active and is not causing a DTC light
KESSY
1321
GATEWAY
1321
Greatly appreciate your help with this.
They are:
ME:
P1627
Instrument Cluster
1321
KESSY
1321
GATEWAY
1321
You have a communications failure over the CAN Bus.  This is going to require checking the bus it self as well as testing the individual controllers for the codes.
is there anything I can do to help narrow down things?
Resets, connections, etc?  Any relearn processes?
Inappropriate post removed by moderator.  RennTech does not support or condone the violation of anyone's intellectual property rights; please reread the board's rules you agreed to when you joined.
