I have a RWD car with a collapsable spare tire, my car came with 18" wheels (25" diameter) I now have 19" wheels (26.5" diameter), in an emergency could I run the spare tire without damaging the ring and pinion?
I think the effect on the rear tires would be like running the car on a really big circular track so probably ok. Does it have traction control or PSM? 6% diff may have some effect on those systems. Not sure though.
Edited by Ahsai
Ahsai...  Thanks for the reply...  yes my car has PSM.  The spare has never been on the ground, but you never know so I appreciate your input.
Um, PSM may not like the 6% diff...
Could you switch off the PSM during an emergency, would that make the PSM happy?
Not sure. My understanding is even if you switch it off, PSM is still monitoring everything in the background. If it thinks something is wrong and you happen to hit the brake, it will re-engage and intervene.
