I am in the middle of a 3.4 996 motor swap into my 98 Boxster and I have to add a wire to the #59 slot in the 88 pin DME plug.
Does anyone know where I can find the female spade that goes into the DME plug?  and also where I can get the insertion tool?
I think I would try the VW repair wire 000.979.009E or 000.979.010E. I used one of these to connect to the Tiptronic plug when I did the (non-eGas) cruise retrofit on my 1998 996, and I think it mightt use the same terminals on the DME. Didn't need an insertion tool. It just clicked in. Sorry I can't tell you which VW wire for sure, but it was about 9 yers ago.
Edit:  Looking at the connector assignment diagrams, I think I might be leading you on a wild goose chase, as the connectors look quite different.  Sorry.
Edited by Richard Hamilton
post-91161-0-29794200-1409881424_thumb.j
This shows the DME 81 pin connector.   Notice that the connector do not match the VW connector you spoke of.   I have used the VW connectors
on my cruze control install but it is not the same as the DME spades.      Still looking anyone have any ideas???post-91161-0-29794200-1409881424_thumb.j
Rich ,  I found it thanks to Ashai!
The Bosch numbers on the white internal section for the 88 pin DME plug are 1 928 401 587 and 1 928 403 122.  That part has two numbers on it.
This plug has two different size spade connectors.  The small spade connector is Bosch number 1 284 477 219(JPT AMP substitute 927 774-3).  The large connector is part number 1 284 477 121(JPT AMP sub. 927 775-3).   Thank you for your help, it was very much appreciated.
I was unable to get a pin out without destroying it.
Thanks,    Bob
Edited by Reebuck1
Anytime.
Maybe too late now but you can make your own pin release tool using a steel hair clip. Here's one I made for this type of pin. The angled tips are critical.
post-5282-0-88944600-1409942644_thumb.jp
