OK, I am prepared to be shot down, however having followed this after an oil change it works for me. I used the maths below to work out how much the oil would expand when hot as against cold. Did the oil change ran the engine for a minute to get the filter full and the pressure up, then let it stand until the time reverted to the 6 second checks. Topped up oil cold until the last segment was not illuminated. When the car/oil is run up to temperature and then the oil is checked it gives a full indication.
Specific volume of a unit can be expressed as
The change in the units volume when temperature change can be expressed as
dV = V0 β (t- t0)          (2)
v = 1 / ρ = V / m         (1)
where
v = specific volume (m3/kg)
ρ = density (kg/m3)
V = volume of unit (m3)
m = mass of unit (kg)
The density of a fluid when the temperature is changed can be expressed as
where
dV = V1 - V0 = change in volume (m3)
β = volumetric temperature expansion coefficient (m3/m3 oC)
t= final temperature (oC)
t= initial temperature (oC)
ρ1 = m / V0 (1 + β (t1 - t0))
    = ρ0 / (1 + β (t1 - t0))          (3)
where
ρ1 = final density (kg/m3)
ρ0 = initial density (kg/m3)
Volumetric Temperature Coefficients - β - of some common Fluids
  • water : 0.000214 (1/oC),
  • ethyl alcohol : 0.00109 (1/ oC), 0.00061 (1/oF)
  • oil : 0.00070 (1/oC), 0.00039 (1/oF)
OK, tin helmet on, awaiting flak  :eek:
Very simple. All you need is the last line - oil expands 0.00039 per degree.
Hot engine ~220F and room temp ~75F and that's 145F temp difference. The oil volume expansion is then 0.00039 * 145 = 5.6%
5.6% of 9L of oil = 0.5L
