Just bought 08' Cayman S tiptronic, when moving automatic gear lever from park to drive there is a bit of resistance and you kind of have to force it a little bit. Been reading about shift cable may be dirty , loose or broken or binding. Checked shift cable under car on drier side and it was pretty dirty and had residue that was hardened on it. cleaned it all up but still hard to move gear lever. The only thing is that the shift cable on the driver side on trans is a bit loose. Could this be cause of why its hard to move lever? Dealer said it could be shift cables binding, how to tell or what to and where for binding shift cables. Thanks ALL
