can anyone tell me whether it is ok to use DOT4 brake fluid in a 1980sc. I see the owners manual recommends DOT3, but I am doing a fluid change on my 996tt at the same time and would be easier to be using the same fluid?
DOT 4 (or "super" DOT 4) fluids are backwards compatible to vehicles that used DOT 3.  Basically, DOT 4 is a dryer, higher boiling point version of DOT 3.
