I've searched and see some references, but no diagram.  I have a 99 Tip engine I am putting in a 99 Manual car and need to verify the vacuum line routing.  Search on this site keeps kicking me out to the web at Zen search.
TIA
Lon.
TIA
Lon.
There are multiple vacuum line diagrams for these cars, which particular area are you looking for?
The routing from the accumulator and the 2 vac switches.  The one in the front and the one by the starter.
Sorry, I meant where are the drawings?  I have the Cannell pdf's and the Bentley manual, nothing in them.
Ok how about the routing for the switch that mounts above the alternator?
Again, TIA.
The electrical side would be covered in the wiring diagrams found in either the OEM service manuals or in aftermarket sources such as the Bentley manuals.  The vacuum line routing would still be as Loren has already noted.
