I have a 04 CTT and i've tried to set the time on the dash and the PCM and neither works. The time sets and works until i shut off the car and then once i restart the car it starts back at the time i set previously just like groundhog day. Also my Nav system does not work (not that i really care). They appear to be related as they both started acting up after i installed a MoBridge. I've check all connections and everything seems connected properly. Anyone have ideas on what is causing this?
Uninstall the Mobridge and see if the issue resolves itself (Eilenberger's Law of Troubleshooting - Look where you last worked..) If it does contact Mobridge and see if they have an answer.
I already tried that. I am thinking it has something to do with GPS working on the PCM but wanted to see if anyone else ever experienced this and had some ideas. Thanks
