So after 4 months off the road, all is fine except I get the warning light for the Oil Level Measurement not functioning, any thoughts ? The Oil pressure gauge is good
Edited by richardc2cab
Year and model of the car?
The Turbo oil level sensor has been a bit of a problem child over the years, some have had multiple failures while others have had none.  Most likely case is you have either lost the sensor itself , or the wire has become disconnected or even eaten by rodents (not at all uncommon for cars that sit).  The sensor is a rod like affair mounted in the oil tank and held in by one bolt.  Retails around $125 or so.
