Anyone installed a "Sprint Booster Module" on their 996TT?  I am interested in how it performed as well as installation.
Sprint boosters normally just plug in between the gas pedal and the connector, some versions have an extra wired switch that you can mount to a remote location ie near the steering column.
I would think most "enthusiasts" can definately handle the install.
most people seem to like it / if the vehicle is shared with ie. your wife the switched version allows you to turn it on/off.
cheers
Thanks for the reply.  It appears on the 996TT the location for installation is under the dash to the drivers right of the steering wheel, could not be simple like others that plug in at the pedal.  Oh well, if you hear about some idiot being pryed out of a Porsche, just me trying to fit a round peg into a square hole!
For those of you who did not respond or... I installed the SP and it is really amazing.  Obviously no extra HP, but the throttle comes on much faster.
