All,
So I hear "weird noises" coming from the engine compartment... and I'm thinking "Uh oh.. Power steering is finally giving out...", given that I've had to add PS fluid before.
But I pop the cover off - and the PS fluid is fine!
Hmm... than what's that rock grinding noise?  I comes and goes...
So I pop the panel off behind the seats to check the belt and accessories.
And... here we go again, its the WATER PUMP!   Every so often, while I watch it, it goes from running smoothing to a bit of a wobble, with the corresponding bothersome noise!!
Now be big problem with this is that I just changed the pump about 6 years ago... I mean, it doesn't seem like this part should be going out again this soon!  But fine... I'll call Sunset tomorrow and order a replacement.
But the weird thing is that I noticed that the crankshaft pulley has a wobble to it as well.    Is that normal?  My wife was bothered about it, so I figured I might try pulling the pulley off to see if I can get it to "set" differently when I torque the bolt back on.
Any suggestions?
Rich Brown
All,
Any suggestions?
Rich Brown
The crank pulley should not "wobble".
Okay, then I'll pull it off and re-install it this evening, see if that helps.   Called Sunset, so a new water pump is on its way.
