I had my calipers sand blasted in order to paint them. The surface turned out a bit rough. Should I used G2 epoxy paint. ?
Thanks.
PS, I'm rebuilding the calipers as well.
I used VHT caliper paint with great results. I did the brembos on my Evo the same way in the past, and they withstood a lot of high temp abuse. I just got mine done last week on my Carrera. Turned out nicely. post-97426-140729929797_thumb.jpg
Did you sand blasted the calipers? Cause mines got a bit rough surface. That's why I was wondering if the G2 epoxy paint, since is thick would be best. IS the VHT a thick paint?
