Fresh from a dealer checkup a week before I did a WOT run for a few seconds and the car threw an engine light
The codes are as follow:
P1792
Manifold ABS. Pressure or Bar Pressure Low Input Value below lower limit value
P0512
Invalid Data Received from Transmission Impulse Signal
P25344
Turbo/Supercharger Boost System Performance Impulse Signal
Anyone know what could cause this?
I searched high and low and can't find any info on this.
​All  help would be appreciated. Thank you
Its a 2011 CTT thank you
Edited by snappy
