Hi guys,
Can anyone help me out here? Dealer won't do it as they never done the service! I changed oil, filter, air filters, plugs. It is a 2004 cayenne turbo!
This may or may not work for you, i guess some it does and some it doesn't....I have a 2004 CTT and it works for me.
- With key in off position, depress the ODO button.
- Without brake pedal depressed, turn ignition on while still pushing the ODO button.
- You should see a message: "Service Reset".
- Push and hold the "enter" button located on the bottom of the wiper stalk.
- While cotinuing to push the "enter" button, turn off the ignition.
Good luck.
