I have a 2009 Cayenne that, the day it hit 60,000 miles, started getting a serious thumping under the center console. I ordered the new EPS bearing and took it to the local Porsche shop.
They removed the driveshaft and installed the new rubber front and the new bearing. However, the car is still shaking somewhat right around 30 mph. I suspect they did not reinstall the driveshaft the same way it came out, and it is out of balance.
Couple questions - does that sound reasonable? How would they rebalance the driveshaft? Or, do I need to replace the driveshaft as well?
