I am considering to replace those stock rims to possibly aftermarket 20" rims to achieve that unique look. :king: Are there any suggested options for brands and size? Any pics would be helpful. :jump:
Been asking our local Chief technician from the local dealership, I understand that fitting a 20" wheel for street use may damage the steering rack. It will result in some gradual clicking sounds when you are executing a turn. I have heard large wheel upgrades affecting the suspensions and bushings but not the steering gears?!
He claims that the steering rack is different between the V8 and the V6 variants too.
Can anyone confirmed this fact?
Regards
The difference (I believe) is between the standard power steering and the optional (Option 1N3) Variable Assist Power Steering - Servotronic speed sensitive power steering. This shows as available on all Cayenne models.
I don't know why aftermarket 20's would be any different than OEM 20's as faras the steering rack is concerned. Lots of folks here and at rennlist have 22's with no problems, though I think 22's are a little over the top. I have aftermarket Italia AT rims for my snowtires (albeit in 18) and they work fine. I have OEM 19's on mine- it was the best deal when I ordered mine.
Please do not misunderstand, the Chief Technician did not discriminate against the use of aftermarket rim. He simply mentioned that 22" had caused steering rack problems for several CTTs already, so he suspects that 20" may cause similar problems for the CV6 with the standard setup although no V6 has installed any ultra large wheels yet.
It seems that the OEM 20" option is not applicable for the V6, is this true?
Does anyone here use Kahn Design wheels or have any comments about them? Those rims look great and seem reasonably priced too.
Why would 20's not work for the V6- the suspension is the same as the V8 isnt' it? Maybe springs rates are a little different because the engine doesn't weigh as much, but otherwise the suspension design is the same...
That fact puzzled me too. :eek: My V6 has PASM just like the turbos so I guess there should be no issues with regards to the suspension system but then again, the steering rack is a different matter. <_<
