How to Replace the AOS Bellows
You will need a pliers, bellows, and size 20 EZ hose clamp. Must be the type that can be finger tightened. Nylon zip ties with not work. They have a maximum operating temperature of 185 F.   Remove the driver's side rear tire and place on stand. Verify broken bellows. Take your left hand, start from the front of the wheel hub and guide it into the cavity between the engine and transmission. When you pass the chassis wall, turn right and up. There you should feel the bellows and two hose clamps
