My 02 carrera 4s docent have a cd magazine inside its changer.so I purchased a non working changer just because it has a magazine inside to use. Any idea how I can power it on so I can eject the magazine ?
If you apply power to the cd changer (assuming it works well enough for that) then you should be able to eject the cartridge.
Black wire should be +12 volts
Chassis is ground.
