When replacing the rear window regulator I moved the top manually. Now the top will not operate normally, and the top not latched warning lamp is on. The dealer wanted $450 to re-calibrate the top.
Question; Can the Durametic re-set/re-calibrate the top?
Also can the Durametic set the key "fob" to open the hood "trunk" and allow the horn to alert on fob locking.
Thanks for the help.
"Question; Can the Durametic re-set/re-calibrate the top?"
Yes, Durametric can re-calibrate the cab top.
"Also can the Durametic set the key "fob" to open the hood "trunk" and allow the horn to alert on fob locking."
No, Durametric can not program functions that are not available in the 996
