Are these anything to be concerned about?
There are no obvious symptoms driving or using the car, I just caught these when I hooked up my Durametric to clear an airbag light I set off myself when I installed my new handbrake assembly.
'07 987 S, 48k miles.
TIA,
Graeme
Porsche Access System - PAS
      Current Fault Codes
8004:
Terminal 50
Rear Body Module
      Current Fault Codes
8050:
Passenger compartment monitoring communication
Seat Memory
      Current Fault Codes
C102:
CAN single-wire operation "comfort"
  • 2 years later...
I have the exact same codes in my 07 Cayman. Did you ever get to the bottom of it? I cleared mine and they always return. The car is stock, other than an aftermarket Pioneer headunit that often cause CAN errors. I have coded out the radio and related components, but these never go away.
